MSE & restore point
prukeyhi
Workaholic
Power User
hi
is there any solution yet to the annoying issue, that each definitions update there is restore point creation? how can i disable it?
(vista HP)
thanks!
    LENOVO G-530
    # Intel Pentium Dual-Core T3400 (2.16GHz, 1MB L2 cache, 667MHz FSB) # 15.4-inch glossy 16:10 display (1280x800) # Intel Graphics Media Accelerator 4500MHD # 3GB DDR2 667MHz RAM # 250GB 5400RPM HDD # SuperMulti DVD+/-RW Optical Drive # Broadcom WiFi (802.11b/g), 10/100 Ethernet, Modem # 6-Cell 11.1V 53WHr Battery http://www.notebookreview.com/default.asp?newsID=5022&review=lenovo+g530
hi
(vista HP)
thanks!
Hallo prukeyhi, i dont think there is any way to stop it other than turning system restore off which would leave you with no back up (not a good idea)
If you want to reduce the amount of restore points then have a look at step 14 in this tutorial http://www.vistax64.com/tutorials/76073-disk-cleanup.html this will delete all but the most recent restore point.
I hope this is of some help :)
    Hewlett Packard, compaq presario CQ60-305AU
    AMD Athlon QI-46 2.1 Ghz
    Wistron 303C
    2048 Mb DDR2 SD Ram
    NVidea GE Go Force 8200M G / 256Mb dedicated grapics memory
    MCP78S NVidea High definition
    15.6" High Definition Brightview Widescreen
    1336x768
    Toshiba MK2555GSX ATA
    Synaptics PS2/Touchpad
Thanks for the tip !
i asked also in Microsoft forum & report later ...
    LENOVO G-530
Hello Prukeyhi
You can also download CCleaner.
With this program, you can manage your system restore points individually.
Click left on Tools, and then System Restore.
Here you can remove any restore point individually.
Download CCleaner 2.33.1184 - FileHippo.com
    Acer Aspire 5738G-644G32MN
    Intel Core 2 Duo - clockspeed 2000 MHz
    Acer JV50
    RAM 4 GB - SO-DIMM DDR3
    NVIDIA GeForce - G105M - 512 MB
    1366 x 768 Pixels
    Hitachi HTS543232L9A300 320 GB - Type SATA - Speed 5400 rpm
    Logitech Wireless Mouse M505
    Azerty
    Currently 14.5 MB/Sec which means 1.8 MB/Sec effective
