Mr Needs Question about 64bit
richc46
Qute from Mr Needs in Another Thread
far cry 2 is optimised for vista, you shouldnt need to run it in compatability mode, so i dont know why you are. and 64 bit vista shouldnt be a factor as 64bit operating systems have backwards compatability for 32bit applications. this appears to be an issue with your setup, any chance you can fill in your system specs?
Mr Needs, you made the above quote in another thread. My question is: If I go to the windows compatibility site and it shows certain softwared(Google Earth and Scrabble) not to be compatible with 64bit, but compatible with 32, is it your position that, I have backwards compatibility with my 64bit specs and can download and use the software?
Thanks
Thanks
does this answer your question mate?
click on the attachment.
and look at the taskmanager, see how some applications have *32? that means that they are native 32 bit and are being emulated in 64bit.
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
Thanks
Thanks for your help and your definitive answer.
