MP GameSpy Problems(no servers listed++!)
Rusty-The-Cat
Just installed the software, I usually use 32-bit, but decided to try 64. Installed fine, found drivers from nVidia, etc.. no problems. Installed Halo, at first it mentioned problem with GameSpy servers, then it listed servers, but didn't specify their ping, strange. I can play the game, so it will connect to them. Next, installed Medal of Honor: Allied Assault and Breakthrough, all fine. Went to play, no trouble, then to MP, again with GameSpy providing the servers, none are listed. Updated, nothing. Tried changing Firewall, no effect. Running as admin., under xp, no change. Reset the router, for the new install (OS), no change. Oh, and went to AMD for dual-core driver. Am I missing a 64-bit add-on, or something?
Anyone have a solution?
AMD Socket 939 FX-60 with Asus A8N-SLI Premium MB
Seagate 250G SATAII , 3G Corsair Platinum DDR
EVGA 8800GTS 512MB Video Card
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
