Mouse pointer resets after system restart.
austin93
Hello. I have an HP pavillion dv9700 notebook. Whenever I choose a mouse pointer (or make one myself), and then hit "apply" it shows up. After my computer is turned off. If I turn it back on (or it is restarted), my mouse pointer resets to the plain white arrow. How can i fix this? Thanks.
Using a logitech mouse?
To avoid the resetting problem, you need to uninstall Setpoint and go to the
Startup memu typing "msconfig" after hitting run on the start memu. Even
after uninstalling Setpoint, it still remains in the startup menu. You need
to uncheck them so they don't automatically load on reboot. Once you do
this, your problem should be resolved.
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    Wireless Microsoft 3000
    10 mbps/2 mbps
