You should upgrade or use an
alternative browser .
no matter what i do at times left click opens closes application with out it stay open its like i clicked to close app
i just uipdated drivers i hope that was it
lenovo
intel quad 2.4
6GB PC2-6400 DDR2 SDRAM memory
in vidieo
High Definition Audio, 8 speaker configurable
650GB 7200RPM Serial ATA hard drive
One quick way to find out is to do a system restore to the day prior to driver updates. If that resolves the problem, then updates drivers one at a time to find the culprit.
AMD AM2 6000+
Nvidia M2N-E SLI
GeForce 7600GT
WD
Cooler Master
Three fans
Dell Optical
Dell Quietkey
10 MBPS
im sorry i confused me and you
wasnt any windows update, i installed the mouses driver seems better
lenovo
intel quad 2.4
in vidieo
Hello Mark,
You might double check your mouse "Double Click" speed in Mouse Properties in the Control Panel to see if it may be to sensitive. If you have a touchpad, then you might also check it's tapping sensitivity settings as well.
Operating System
1TB Samsung 990 PRO M.2,
4TB Samsung 990 PRO PRO M.2,
Galaxy S23 Plus phone
Operating System
thanks i slowed it down some more i hope that helps
this just started past few days, nothing new added
lenovo
intel quad 2.4
in vidieo
You're welcome. Please let us know how it goes.
Operating System
Operating System
