designdiva925
I can't click on any link inside an e-mail!! I get this error.....[Window Title]
http://www.vistax64.com/register.php?a=act&u=119811&i=88ed7ab0d67d7b4b1058ca2983717b94ba38658b
[Content]
Windows cannot find 'http://www.vistax64.com/register.php?a=act&u=119811&i=88ed7ab0d67d7b4b1058ca2983717b94ba38658b'. Make sure you typed the name correctly, and then try again.
[OK]
So I tried to redownload my Dell SE178WFP LCD Monitor cd but it gave me the error message above.I keep getting an error that says "Windows cannot find 'E\monitor.htm'. Make sure you typed the name correctly and then try again".
Is this a registry issue? Or an html issue? This all started when I upgraded to Vista Home Premium and installed Adobe CS4.
What should I do?
[Content]
[OK]
What should I do?
- Dell
- Intel(R) Celeron(R) CPU 440 @2.00GHz
- 2.00 GB
