Monitor Calibration
Submarine
Vista Pro
So, not really Vista related.
Lately I have been trying to learn the basics of digital photography, being busy developing a couple of thousands raw pix, taken over the summer. Now, I got I a Spyder3Elite to calibrate my monitor. This was more of a manual piece of work than I expected. My Spyder is running in version 3.1.1. I have a Dell 2407WFP-HC (high Gamut) monitor. My pix will be shared with other people (not over internet) and printed at home and in labs.
Anybody there with experience of monitor calibration?
When using the Spyder in ambient light calibration mode, it suggests I calibrate my display to a white point of 5800 K, a gamma of 2.2 and a luminance of 125 cd/m2 (120 is usually LCD default). 5800 makes it a bit yellow, I think, so after studying various reco's on the internet, I calibrated it to 6500K instead. Better.
The monitor has controls for brightness and contrast. The manual says that "Brightness adjusts the luminance of the backlight" and "The Contrast function adjusts the degree of difference between darkness and lightness" (well, surprise).
To adjust luminance, I should adjust brightness first and then contrast to achieve my desired luminance.
To do this, I used a "grey scale" and reduced the brightness control until I could barely see a difference between the two darkest boxes; then contrast until I got 125 as my measured luminance.
Basically, this method, to first adjust the brightness control and then the contrast, gives an endless amount of possible settings, starting with brightness at 0.5% and contrats at default 50% to whatever. I ended up with brightness at 26% and contrast at 42%, but I cannot say if this is the best choise when I develop my raws.
Anyone available to give me guidance?
Is there a good grey scale anywhere on the net to find the best setting?
How much does it matter, what settings I choose?
    Dell XPS720
    Intel Quad Q6600 2.40GHz
    4GB DDR2 800MHz
    Creative SB X-Fi Xtreme Gamer
    Dell 2407WFP-HC
    1920x1200
I have heard of companies in the US who will match printer and monitor so what you see on one matches the other. But I don't see how it could work...
Monitors deal with light, printers deals with toner or ink. There are going to be differences between the two simply because they are different media.
Years ago I was, for a short while before changes university majors, a theatrical design major. One of the other students asked the tech director and the scenerary director about color matching in light and paint. After they stopped laughing, they pointed out it is almost impossible.
Note this was long before digital cameras.
Color matching between the two will likely depend on how much money you are willing to spend. You might look the info up locally and ask them their basic prices.
Last I heard, over 5 years ago, it cost around $1,000 US to match a printer and a monitor for color match.
    Acer Aspire X1700
    ASUS
    3 gigs
    EVGA 1 gig GeForce 210
    Vizio 21" tv
    1920x1080 resolution
    fans that came with it
    basic USB
    basic USB
Oh, note that the results you and others see will depend on their and your color vision. Something you cannot control, and the seeing results could vary wildly, even if all of the printers and your monitor are color matched.
    Acer Aspire X1700
    ASUS
    3 gigs
    Vizio 21" tv
    basic USB
    basic USB
oh god i went trough all this when i got my 2209wa it was nightmare , wish i had a spyder
it seems odd that it suggested 5800k when 6500k is used by windows as the white setting?
what are you looking at for colours? did you adjust the RGB manually? the way i saw it was the brightness made no differance to the colour settings or the gamma as it was only a backlight so you set it how you feel comfortable
your spyder is always the best way to calibrate as you know but i used a site when i was messing with mine
LCD monitor test images
more info here
Monitor Calibration Guide
in the end i downloaded a colour profile from somebody else who had the same monitor and a spyder :confused:
calibrating your printer is down to yuor photo software you can use it to select and use the same colour profile as your monitor
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
Thanks Archie, that was useful links. The spyder measures the ambient light conditions, and at the fairly dark conditions I work in, it suggests 5800. In a brighter room it goes up to 6500, but I find 6500 looks "better", less yellow tone, so I decided to stick with that, but to follow the luminance reco of 125, slightly higher than the LCD standard 120. For a LCD, adjusting the luminance is "manual" with the OSD, with spyder measurments in between the adjustments. The rest is automatic with the spyder. Though I know, I will end up with the "correct" luminance, I cannot help thinking it matters if I have the contrast at 38 or 50 or something else. The link will certainly help me calibrating, assuming the method I use is correct.
I have not really thought about calibrating for printing yet, this is just a first step to help me develop my raws into jpg. I know many professionals work at 5000 (with indoor lamps at 5000) or 5800 (for good correlation with printers), but I am not so sure it will matter much to me. Next step is to use correct profiles for my printer and paper and see what comes out.
    Dell XPS720
    4GB DDR2 800MHz
    Dell 2407WFP-HC
    1920x1200
the contrast setting usually affects the gamma alot i set mine to 2.2 using that site and i was looking at 45 contrast , but i find 70 better looking ingame so im using that , i set it to 45 if im looking at/editing pics but i dont do that very often
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
Thanks for those links archie, I have two monitors that are being a pain in the a** to match together. The other problem you may get with printing is using different media. The colour of the paper is so subtile that you would not notice it until you have printed.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
