Solved Minimum and Maximum Processor State "Optimal" Setting
snsd
I have Windows Vista Home Premium 32 bit and an AMD X2 Dual-Core QL-60 processor (1.9 GHz).
In Vista Power options, there are 2 settings under Processor Power Management: Minimum and Maximum Processor State.
What are the optimal settings for these options? I fully understand that one might choose to have a lower maximum state when running on battery power to prolong battery life. I can think of no reason to have the maximum state below 100% when running plugged-in (unless, of course, one is trying to save electricity, keep the laptop cooler...)
How does minimum state work and what is the optimal setting? I know the default is 5% (but I've done a lot of Googling and cannot find an educated reason why 5% is the default.) Would it be correct for me to presume that if I set it at (say) 5%, then the processor will never operate below 5% of its capability (or whatever # of MHz is closest to 5% capacity) and will run all the way to the maximum specified state where needed? In other words, am I simply giving the processor the leverage to pick whatever power is required between its minimum and maximum specified states?
If my above assumption is correct and the processor will pick the optimum speed within the min/max range, why would I ever increase the minimum above 5% - and better still, why wouldn't I go right down to 1%? (Having said that, I read in one post that processors don't run in relative percentages - but 500Mhz, 800Mhz or whatever - so if my processor can only go as low as (say) 600MHz and my max is 1,900, then I guess if I set my minimum anywhere between 1 and 32%, it would never go below 600Mhz...)
Thanks in advance for any help.
Dave
    HP Pavilion tx 2000
    AMD Athlon X2 Dual-Core QL-60 1.90 Ghz
    3GB
    ATI Radeon HD 3200
    Realtek HIgh Definition Audio
    WDC 250 GB ATA
re: Minimum and Maximum Processor State "Optimal" Setting
Hello Dave,
It's just basically a way to save energy in both the "Battey" and "Plugged in" states of your laptop by setting a "Minimum" and "Maximum" percentage of what your CPU can run at. Windows 7 will automatically keep your CPU running at "Minimum" when the computer is idle. Windows 7 will also automatically increase the CPU's percentage to handle any workload as needed up to "Maximum", and then automatically lower the percentage (no less then "Minimum") as the workload decreases or finishes.
Here are some recommended settings, but it really depends on your needs and wants.
Plugged in: 5% MIN & 100% MAX
Battery: 1% MIN & 100% MAX (or lower MAX to save more battery, but slower performance under heavy workloads)
    Logitech MX Master 4
Thanks Shawn. I know I rambled a bit - but if I do as you suggested - I presume Vista will automatically use more of the processor as needed? i.e. as long as I keep the max at 100%, I should never have performance issues - even if I drop the minimum down to 1-5%.
Thanks,
Dave
    HP Pavilion tx 2000
    3GB
    ATI Radeon HD 3200
    WDC 250 GB ATA
No problem Dave. That would be correct. :)
