Mind boggling wireless issue + Explorer fail @ startup
titansfaninva
I've been toying with my machine recently because I have lost connection with most of the Internet through my laptops wireless connection. These are some symptoms:
When connecting wirelessly, I can only connect to two sites: Google and Vampirefreaks (social network), and the pages are updating. The entire public parts of this site are accessible via wireless.
When connecting wirelessly to other websites, I cannot connect.
If I'm hardwired straight to my wireless router with an ethernet cable, I can connect to anything with relative ease.
I use Firefox, but the same problems are exhibited in IE.
At startup, Explorer opens but makes that persistent error *ding* whenever I click it. I have to end explorer.exe and restart it in order for it to start working whenever I restart my laptop.
At startup, a pop up alerts me that "One of the USB devices attached to this comuter has malfunctioned, and Windows does not recognize it." Followed by a box showing "USB Root Hub (2 ports) // Unknown Device / Unused Port," recommending I reconnect the device or replace it, but I have no idea how to reconnect a USB hub that is built into the system.
If it's not painfully obvious, I'm not a computer whiz, so I'll apologize now for any incorrect terms I've used and how much help I might require.
If there is a thread with a situation like mine, I've not seen it and would be interested in reading through it as well as your recommendations.
Thanks in advance.
Bill
    Gateway P-6831FX
    Intel(R) Core(TM)2 Duo CPU T5550 @1.83GHz
    3.00 GB
titansfaninva,
You listed 3 problems:
1. Wireless connections are flakey while hardwire works fine.
2. Explorer does not load correctly on startup but is OK if ended & reloaded.
3. On startup, there are two USB error messages.
[FONT=&quot]What happens if you boot your PC in "safe mode" or in “safe mode with networking”? (regarding problems 2 & 3)
The following link about safe mode is for WinXP but should apply to Vista as well:
[/FONT]Microsoft Corporation
Sky
