Microsoft .net framework problem
seanso
here my problem when i run registry cleaner in vista manager
Microsoft .NET Framework
Unhandled exception has occurred in your application.
attempted t read or write protected memory. this is often an indication that other memery is corrupt.
for detailed it show long list of description....
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
at System.Drawing.SafeNativeMethods.Gdip.GdipDrawString(HandleRef graphics, String textString, Int32 length, HandleRef font, GPRECTF& layoutRect, HandleRef stringFormat, HandleRef brush)
at System.Drawing.Graphics.DrawString(String s, Font font, Brush brush, RectangleF layoutRectangle, StringFormat format)
at System.Windows.Forms.Label.OnPaint(PaintEventArgs e)
at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
at System.Windows.Forms.Control.WmPaint(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Label.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
RegistryCleaner
Assembly Version: 3.3.0.0
Win32 Version: 3.3.0.0
CodeBase: file:///C:/Program%20Files/Yamicsoft/Vista%20Manager/RegistryCleaner.exe
What registry cleaner are you running.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
That doesn't look like a .NET issue, it looks like a bug in the application you are running. If you really want to use that application try contacting the developer for support. Or just get CCleaner.
