Microsoft Dungeon Siege problem SP1
Adriaan
Microsoft Dungeon Siege: Legends of Aranna does not work after updating Vista x64 Ultimate to SP1, if anyone knows how to fix it, please let me know
    Intel Q6600 Quad Core 2.4 Ghz
    Dell 0TP406
    Nvidia 8800 GT 512 MB
    Dual Dell 22" Widescreen
    3360x1050
    320 GB Internal Main 500 GB USB External 160 GB USB External 2TB USB External
    DSL 3MB
Hey Adriaan,
I worked this out. The error is to do with the CD check at the start. So... think of a way to remove the CD check (probably can't say it on this forum). Also set compatibility to XP SP2. Just tried out Lazarus successfully.
Good luck.
Hey Adriaan,
Good luck.
Hmmmmm stealing software are we?
    Intel Core2Quad Q9450
    nForce 790i Ultra SLI(evga)
    8 GB DDR3 1333MHz
    2 e-GeForce 9800GX2(SLI mode)
    WD1500AHFD (Raptor 150 GB 10,000 RPM)
I have Dungeon Siege Legends of Aranna working just fine on my system.
Come come now, no stealing of software.
What I did, was to on the compatibility tab for the game shortcut, was to set check Disable Visual Themes when the game starts up.
    Core 2 Duo E6600
    Intel 975XBX2
    8GB's of DDR2 800
    Radeon 3870X2
    HT Omega Claro
    Viewsonic VG2030wm Widescreen LCD
    1680X1050
    120GB 200GB 320GB
    ThermalTake Toughpower 700
    Antec P182
    four 120mm fans
    Microsoft Wireless Intellimous Explorer 2.0
    Microsoft Natural Multimedia Keyboard
    10MB
    16X LG DVDROM & LG Dual Layer DVD Burner Logitech X-540 speakers
No one said anything about stealing anything. Using a no cd crack on a purchased game is fine. I know alot of people who have never downloaded anything illegal but use no cd cracks on every game they played, mostly so they dont have to switch cds, and in rare cases like this one, to avoid buggy cd checks.
Sorry to bring this old thread up again.
I got vista X64 with SP 1, and an orginal DS LOA.
However I cannot seem to play it, there's always an arror message and when you press enter several times, you are prompt to "please insert your Game CD --> click OK or cancel" When I clicked OK, the same error message apperars again an so on and so on.
I've tried installing the latest Win Vista May 2008 compatibility pack (KB94756), set compatibilities to Win XP SP 2, disable visual themes, but none of them works.
Any advice on how to start the game?
    Intel Core 2 Duo E4300
    Asus P5N32E-SLI
    A-Data DDR2 800 4 x 1 Gb
    XFX 8600 GT XXX Edition
    Western Digital 320 Gb Maxtor 80 Gb
Do you have another partition / HD available? I find that running older games, especially those not written for Vista, work a lot better when trying to run from a non standard location (IOW, *not* from C:\Program Files or C:\Program Files (X86) )
The reason is that Vista marks the Program Files directories as protected areas, so that any thing that is not run with the Trusted Installer privilege is not allowed to write data to those folders, or any sub folders.
An alternate that you can try is to run the program with admin privileges, that might get the CD Check working correctly.
Another alternate is to take control of ***that game folder*** only.
I still recommend installing to a different location on a different HD / partition. If you have that available, do a custom install and tell it to install in D:\... (just replace C with D) where D is your other driver letter.
***NOTE*** DO no try using an external drive - that will be more headache than you care for.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
I installed it into my second hard drive, so it's completely a different drive than C:\Program Files (X86).
    Asus P5N32E-SLI
And did you try my other suggestion? Running the program as admin?
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
I tried running as admin, but the same error appear.
The error message says:
Error, fatal exception occured (can this object be used in this manner?), HResult = -2147319779
In function: cInvokeMethod2::Invoke
Please insert the CD
Any suggestions?
    Asus P5N32E-SLI
I too have the same problem. I've tried all the suggestions here and nothing works. Vista refuses to run the original Dungeon Siege. I've even tried speaking to a Microsoft Tech Support person, they, of course are NO help at all. They couldn't even understand what the problem was no matter how many times I explained it. Not surprised. Sorry, but, Microsoft has a bad rep when it comes to tech support and knowing the products. You can make them but you sure can't fix them.
Okay... I don't mean to bring up this old topic, however... has anyone had any luck with this situation?
I have tried all the suggestions (other than installing on a separate partition or hard drive, since I don't have one). However, I did take control over the folder where the game is. It still isn't working.
Is there nothing that I can do to get this game to work on Vista?
I assume that this same problem with haunt Dungeon Siege II?
*sighs*
Maybe we need a new Dungeon Siege... or maybe a better OS that can play legacy games.
