microphone
I looking for a good microphone for computer. Any body have a good suggestion. I tried some cheap ones from local retailers, but they don't pick up sound at all, unless you hold it right to your face.
    Self built
    AMD Athlon 64x2 6000+ 3.0ghz
    Asus M4N78 Pro
    3Gb PC2-5300 DDR2 @ 667mhz
    VIA HD Audio
    OEM HP
    OEM HP
Those cheaper ones are probably directional microphones. But they should work.
I use a logitech headset & mic (comes with two jacks) and it works quite well for my needs.
So...the mic for you depends on what you want to use it for...of which we could only but guess
I want to use a microphone with webcam and incredimail program for the kids.. The one I tried was at walmart for $8.88, a stand up w/base that could fold up for use and down when not in use. I not sure how a ear piece or head set would work, it should work just like a regular mic. I'm guessing. thanks for the input. Brand name and tech info is what I am looking for.
    Self built
    Asus M4N78 Pro
    VIA HD Audio
    OEM HP
    OEM HP
