Men of Valor Character Problem
Madandfrustrate
Interpretor
Whenever I try to play Men of Valor: Vietnam, everything runs fine and smoothly, except for the character animations. They slide across the ground, and set animations occur (When they stand, their arms are spread out towards their sides, and equipment is not properly attached to the models). Also, reload animations do not activate. Any insight on this problem?
    Gateway DX4860
    Intel Core i5-2320 @ 3.00GHz
    6GB DDR3 SDRAM
    Zotac GeForce GT 240 1GB GDDR5
    Intel H67 Express
    Samsung SyncMaster 2253LW
    1680x1050 @ 60Hz
    SATA II 1.5TB Hard Drive
    450 Watts
    NexxTech Wired Optical Mouse
    HP 5189
    Telus High Speed 15mb/s
Not really. My drivers are up to date, Windows is up to date, Direct X is up to date, my specs can handle the game and I don't have Windows 7.
    Gateway DX4860
    6GB DDR3 SDRAM
    Intel H67 Express
    1680x1050 @ 60Hz
    450 Watts
    HP 5189
In this situation Windows 7 is the same as Vista. If I come up with anything I will let you know.
Thanks. I looked it over and didn't see anything that really affected me, since I had already checked them.
    Gateway DX4860
    6GB DDR3 SDRAM
    Intel H67 Express
    1680x1050 @ 60Hz
    450 Watts
    HP 5189
Do other games work? If so then I do not think it is a vista problem.
Have you looked on the game website for help?
Please post back your results.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
