McAfee SystemGuard Problem
ajd007
I keep receiving a message in Vista Ultimate 32bit that says "McAfee Personal Firewall Service has stopped working" The problem is listed as "APPCRASH" and the application is listed as MPFsrv.exe. Sometimes I also get a message that says SystemGuard has stopped working. I have had McAfee Total Protection installed on my computer for about half a year already without any problems and this problem appeared suddenly last week. I talked to the McAfee customer support and they told me to download a patch, which I did. However, this didn't fix anything. I have tried reinstalling McAfee (using the special program that removes all remnants of the program that remain after you do a regular uninstall), but the problem persists. I have changed nothing on my computer recently.
I also have the same McAfee program installed on my other computer, which has XP, but the problem does not appear there. Is anybody else getting this problem?
I would get rid of MacAfee. It is crap. Stay away from Symantec for same reason. Avast is decent anti-virus software. I use just Windows firewall and MAC filtering on my router.
    16GB DDR667
    SAS RAID
Actually I would stay away from both McAfee and Avast as both have failed recent Vista sp1 antivirus testing.
http://www.vistax64.com/system-secu...pril-2008-vista-sp1-test-failures-vendor.html
McAfee
Status: FAIL
Failure reason: 1 wildlist miss
Avast! (Alwil)
Status: FAIL
Failure reason: 19 wildlist misses, 1 false positive
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    Wireless Microsoft 3000
    10 mbps/2 mbps
