I recently purchased the full version of mBAM after several "rogue" invasions. It's doing a good job of capturing these buggers. Lately, however, the MBAM icon hasn't been showing up on the taskbar or taking a long time to show up. Is this a problem or normal behavior? Also a question about settings. In the "Action taken for peer to peer software" the default is "do not show results". What's the recommended setting for this dropdown menu? Thanks.
- HPs3700y Slimline
- AMD Athlon64 X2 (B) 50000+ 2.6 GHz (65W)
- Asus M2N61-AR
- 3 GB
- NVDIA GeForce 6150SE nForce 430 (Integrated on motherboard)
- High Definition 6-channel audio ALC 888S chipset
- SAMSUNG SYNCMASTER 914V FLAT PANEL LCD
- 1280 X 1024
- 320GB SATA 3G (3.0 Gb/sec)
- PSU
- 160W
- Logitech Marble Mouse
- HP
- Broadband Cable Connection (256 Kpbs?)
- Other Info
- Not sure what case or cooling means. Could not find in any documentation. The keyboard is the standard that comes with the HP Slimline.
