Max amount of RAM for Vista 32bit?
Wifout Teef
Hi what is the max amount of RAM that Vista 32 bit will recognize?
I ask this because I have 3 gigs of RAM currently on my 32 bit computer and I want to go buy some more. I found a good stick for under 20 dollars that I don't mind spending on.
If I make my RAM go from 3 gigs to 4 gigs, will it recognize the extra gig? I heard that it will not recognize 4 gigs but I also heard that it won't recognize anything more than 4 gigs.
Thanks.
How big is your graphics card? That is included in the amount of memory your OS will be able to address.
    Sager NG2096
    Intel P8700
    4 Gigs
    9600M GT
    Samsung PN50A550
    Primary 1680 X 1050, Secondary 1920 X 1080
    Logitech MX Revolution
    Satalite :-(
    Running SUSE, Solaris, Kalyware, and BSD through vmware whenever the mood strikes
Oh man I forgot how big it is.
It's a 9800 gtx+ which I think is overclocked. The memory in it is over 1 gig I remember that. I think it was nearly 2 gigs.
Thanks.
Hi Wifout Teef,
A 32-bit OS is limited to a total of 4gig of memory which includes the video card memory. Thus if your video card is 2gig and you have 4gig of system memory, the video card memory will be first used, then the system memory, thus you would have your video card memory plus the remaining system memory to make up the total 4gig. In this case you would effectively lose the other 2gig of system memory.
Here's a good article explaining this here - http://www.corsair.com/_appnotes/AN804_Gaming_Performance_Analysis.pdf. Note this is a .PDF file so you will need Acrobat Reader to read it (in case you don't have it)
    Intel D975XBX2
    ATI Radeon HD 4890 (1GHz)
    hp w2207h (22" widescreen)
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
    Logitech Wireless Wave
    Sager NG2096
    Intel P8700
    4 Gigs
    9600M GT
    Samsung PN50A550
    Satalite :-(
Eh I've heard a lot about certain games not working with 64bit. Also a lot of programs aren't compatible. I don't think I'll get it. Thanks for your help
Do the research on the game you're interested in, then decide if you want to switch to 64. For what its worth most of todays games works well with Vista 64. Yes 64 does still have some driver and software issues (unfortunately), but these issues are slowly going away. Again, do your research before buying into the "64 bites for games hype"
Just my two cents
    Intel D975XBX2
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
It's not like vista x64 can't run 32 bit software. Unless you have some super niche software on your computer, I don't think finding something that works is going to be an issue. Drivers sure, if you don't have some modern hardware then you may run into issues, but then again if you don't have some modern hardware I'm wondering how you're running vista. Do a bit of research, you'd be surprised how usable it actually is.
http://windowshelp.microsoft.com/Wi...1554-d5ef-4f2c-8fb9-149bdc5c8a701033.mspx#EDH
    Sager NG2096
    Intel P8700
    4 Gigs
    9600M GT
    Samsung PN50A550
    Satalite :-(
I have never had a problem with program compatability.. x64 doesnt mean than x86 (32-bit) programs will not work
    Acer Extensa 5620-6396
    Intel Core 2 Duo 5750
    4GB DDR2
    ATI Radeon HD 2400 XT
    Laptop 15.4 LCD
    1280*768
    Logitech G11 Gaming Keyboars
64 bit Vista has run all my games without any problem. Even the original Fallout ran without a problem haha.
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
hey guys i need help
with my netwok adapter for my wireless router.
If you made a topic, then wait for someone to respond, otherwise make a topic. Don't go hijacking posts.
    Sager NG2096
    Intel P8700
    4 Gigs
    9600M GT
    Samsung PN50A550
    Satalite :-(
Thanks guys I'll look into it.
If you didn't have such a beast of a graphics card I wouldn't be so quick to suggest X64, but you're clearly serious about giving your system max resources so it'd be wise to eliminate the OS bottleneck.
    Sager NG2096
    Intel P8700
    4 Gigs
    9600M GT
    Samsung PN50A550
    Satalite :-(
