Hey there, My laptop is odd.
If I leave it on my bed on soft material, it tends to heat up to an excess of 70C...
If I put it on a hard, wooden surface that is my desk, it will reach up to 85C.
That ain't right. This is according to both Speedfan and Core Temp.
When I play games, only allowing my process power to go as high as 60%, it will overheat and shut down.
This was the case since I had it really, so I don't think it's a dust problem, although I know I shouldn't have it on my bed like that, so I do try to avoid such things.
I've ordered a little heat mat thing, but I'd like to know what's going on, and how to fix it; it can't be healthy, and I'd like to actually use my laptop at 100% as opposed to 40%
Thanks a lot!
Andy
Ps
Some details are:
Vista 32bit
3GB ram
Core 2 Duo T7500 2.2Ghz
Nvidia Geforce 8600GT (8600 something anyway)
120gb 5400rpm hard drive
Thanks a lot!
Andy
Ps
Some details are:
Vista 32bit
3GB ram
- Rizeon FL 90 Custom
- Core Duo 2 T7500 2.2ghz
- Phoenix
- 3gb
- Nvidia Geforce 8600GT 512mb
- Crystal bright
- 1280x800, 15.5 Inch
- 120OGB SATA 5600rpm
- Something terrible and restricted
