Major Vista Fresh Install Problems
737Best
Hi everyone!
I'm new to these forums and I really need help with vista. I have had no trouble instaling it in the past. But all of a sudden one day I chose to freshly install vista. So using the standard installation procedures and when I went to install my netgear usb wireless adapter Which used to work failed to install. I thought it was the adapter so I upgraded to a very nice d-link usb adapter...and that too failed to install. So I installed a fresh copy of so on he same drive and reformatted it and that worked just fine. So I tried reinstalling vista and of course it didn't work. So now I'm really confused and typing this on the only available Internet device which happens to be an iPod touch LOL. Does anyone have an idea as to what is going wrong? Btw I have an oem copy of vista ultimate x64 pre sp1. The netgear adapter was the wusb111 and the d-link adapter is the dwa 160.
I am very desparate!
    AMD Athlon 64 fx60
    Asus A8N Sli
    4gig GSkill PC3200 Dual Channel
    BFG nVidia 8800gtx OC
    Integrated Soundcard
    21" HP2159m
    1920x1080
    2x 230GB SATAII @ 7500RPM (1 WD, the other I think is a Samsung) 1x 500GB SATAII @ 7500RPM 1x 500GB USB2.0 WD MyBook 1x 250GB USB2.0 WD Passport
    600W Ultra somethingerather
    Some Crappy Ultra Case
    Stock AMD CPU Fan (Yikes!) + 2x 120mm fans
    Logitech G5 Corded Laser Mouse
    $11 Microsoft Keyboard
    Slow
    Windows 7 Beta Building a new core i7 rig soon for Windows 7. Using most of the stuff in this computer.
Hi, 737Best, and welcome to the forums.
A couple of questions: Have you downloaded the 64bit versions of the drivers for either of those NICs?
And by
did you mean XP?
If so, is it XP 32bit or XP 64?
Have you always been installing Vista Ultimate x64? or was it Vista Ultimate 32bit before and now it is not working with X64?
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Ah sorry, the iPod "corrected me"
The copy of windows xp I have is MCE, so it's 32 bit. However windows Vista is and has always been Vista Ultimate x64
    AMD Athlon 64 fx60
    Asus A8N Sli
    21" HP2159m
    1920x1080
    Slow
OK, with Vista, are you sure you are using the Vista x64 drivers?
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
I am positive I'm using x64 drivers. My Mobo came with a disk, but only for 32 bit (i know they have x64 through an online update). Besides, I don't think the Mobo USB drivers are the issue because my USB mouse is working. The D-Link Adapter I am trying to install has x64 adapters
    AMD Athlon 64 fx60
    Asus A8N Sli
    21" HP2159m
    1920x1080
    Slow
OK, you do know that there are 2 revisions of the D-Link DWA-160 USB Wireless Adapter, right?
http://support.dlink.com/products/view.asp?productid=DWA-160
http://support.dlink.com/products/view.asp?productid=DWA-160_revB
Did you use the *right* one?
BTW, I checked the LinkSys website at Linksys.com - Support/Technical Support/Linksys Windows Vista Support/Download Vista Drivers and do not see your original USB adapter working in Vista at all...according to that site....
But the D-Link should work just fine, as long as you get the *correct* drivers.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
