Major problems with Home Premium 64
Celticparadox
Hi all
Im looking for some help with my build...ill post the components
Intel Q9400 Quad Core
EVGA 750i SLI Motherboard
2x XFX 8800GT Alpha Dog Videocards
8g OCZ Platinum Edition RAM
1 WD Velociraptor 300g drive (main)
1 WD Green 1 TB drive (storage)
Alpine Cooling Pro Freezer 7 (cpu heatsink)
Vista Home Premium 64 bit
Now to the issues
The install of Vista has been nothing short of a nightmare..the OS keeps locking up at random intervals and reducing me to tears. I can't even seem to get the drivers installed without issues. I have tried to do most from safe mode to no avail. The next step was to remove all but 2 g of RAM and one of the video cards but things are still locking up for no apparant reason. Sometimes the install hung on "expanding Files" sometimes it would make it through that only to hang at the splash screen or once the os had booted up. We ten tested all the RAM with a ram test and everything was fine. Im at my wit's end here as I have pulled everything out to make it as bare bones as possible.
One thought from a friend was that the raid drivers may be causing an issue as this has been known to happen on intel mobos. Although I thought I had the Raid driver off anyway as Im not doing an array....yet. Has anyone had issues like this and if so could you impart your results please and thank you.
    Intel Q9400
    EVGA Nforce 750i SLI FTW
    8 Gigs of OCZ Platinum ddr2
    XFX Geforce 8800GT 512 mb x2
    LG LCD
    Primary Drive - Western Digital Velociraptor 300g Secondary Drive - Western Digital Green 1 TB
    OCZ Elitextream 1000w
    Antec 900
    Alpine Cooling Pro Freezer 7 CPU Cooler
    Saitek Cyborg
    Microsoft Digital MEdia 3000
Hi Celticparadox,
Check for a BIOS update, reset it back to defaults and also Disable HPET if you have that option in your BIOS (very important) and also try changing SATA ports (Motherboards make some ports slower and other faster)
Steven
Hey Steve
The bios that is in there is brand new...this is the initial setup that im having problems with. The SATA drives are plugged into 0 and 1 (or 1 and 2) depending.
    Intel Q9400
    LG LCD
    Antec 900
    Saitek Cyborg
You say the BIOS is "brand new", but is it the latest version? Also, use one module of RAM and manually set it up to 5(CAS)-5(RCD)-5(RP)-15(RAS) @ 800(DDR) MHz. Sometimes nvidia chipsets have problems setting up the RAM, causing stability problems. I had RAM problems with a new setup of an XFX 780i. Thankfully they are a thing of the past.
    Q9450 SLAWR
    XFX 780i
    8GB OCZ SLI 5-4-4-12@800
    XFX 8800 GTX 768MB (2)
    Auzen X-Fi Prelude / Logitech Z-5500 Digital 5.1
    Samsung Syncmaster 214T
    1600 x 1200
    300GB VelociRaptor / 750GB / 500GB / 750GB
    Antec 1000W TPQ
    Antec 900
    4 x 120mm, 1 x 200mm
    Logitech G7, Razer Lachesis
    Microsoft Entertainment Desktop 8000
    3Mb
Does anyone have a link for the Phoenix BIOS updates...most of the links I have found are no good
    Intel Q9400
    LG LCD
    Antec 900
    Saitek Cyborg
You can get the corret BIOS from the downloads page of your Motherboard.
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
You will have to register your mobo with EVGA. Also, make sure you know if you have the 750i SLI or the 750i SLI FTW. I can find some BIOS file for your mobo out there but it would be better if you got it from EVGA.
    Q9450 SLAWR
    XFX 780i
    1600 x 1200
    Antec 1000W TPQ
    Antec 900
    3Mb
I got the one from EVGA last night and flashed it and POW no video signal whatsoever. I had to remove the battery and reset the MB to get a pic again...and that was using the correct BIOS
    Intel Q9400
    LG LCD
    Antec 900
    Saitek Cyborg
-that's correct after flashing the bios , power it off or reset it, if the system has a heavy oc default the bios before the update , boot to new bios save with no changes reboot , if raided do the set up , reboot when set up the bios
-you have alot of equipment ,so you should be upping the voltage settings I think like the nb-sb, memory , pll, vtt , gtl's ,I don't have your board so evga mb forums might have a recommend SAFE settings ,my board 780i won't run quads on auto under stress.
-maybe some of that might help.
edit
-you list two drives I hope you only had one installed on the vista install,
-edit 2
-what chipset\nforce drivers did you load , ones on the cd are old?
-ones to use nforce15.23 nForce Driver
-video driver geforce 178.24
    E8600 @ 4.1
    Asus Striker II Forumla
    4x1 ocz pc8500 @960-4-4-4-12
    2xEvga GTX 285 -sli
    FX Xtreem music--Logitech 5.1 surround
    samsung 2443bw
    1920x1200
    2 x vraptors 150 raid 0 1x seagate 250 gig dump drive
    TX850
    cm690
    Air cooled 2x140mm ,1x120mm ,1x80mm in - 3 120mm out
    Mx518
    g15 + G13
    5mb down -.8mb up
    Apc 1000 UPS for computor NO LONGER USE NOT ENOUGH POWER -200w for the monior
yeah i have minimal stuff in for the install..2 g of memory..1 video card, no sli and only the main hd
    Intel Q9400
    LG LCD
    Antec 900
    Saitek Cyborg
UPDATE...after doing a hard reset on the BIOS (removing battery etc) the monster is alive and well and crushing everything in sight. All the hangups have gone away and everything is silky smooth like buttah
    Intel Q9400
    LG LCD
    Antec 900
    Saitek Cyborg
Well done. Nice to have a win!
    Scratch Built
    Intel Quad Core 6600
    Asus P5B
    4096 MB Xtreme-Dark 800mhz
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
yeah im so doing the happy dance over here
    Intel Q9400
    LG LCD
    Antec 900
    Saitek Cyborg
Glad to hear that everything is working smoothly for you now.
Just a tip for you (in case this ever happens again, touch wood!). Look on your motherboard, somewhere near the BIOS or the battery would be a CMOS reset jumper of some kind. RTFM if you don't find it. It's easier and presents less risk than removing the battery.
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Genius
    384kbps
