MichaelDBang
Greetings,
I've been having this issue with Vista for over a year now. I just recently reformatted my machine AND bought a new PCI network card (I thought maybe the problem might be related to the onboard network port/driver) and the issue still persists.
This is a nasty one. My network connection simply cuts out at random times. By random I mean I'll be connected between 15 or so minutes to up to 2 or 3 days before the problem occurs. My network icon down in the task tray will show a yellow exclaimation with the message "limited network connectivity."
The only way to fix this is to reboot. What's worse is that there are no errors in thrown in any of the Event Viewer logs.
I'm hoping someone can direct me to a way of troubleshooting and fixing this problem.
I also VPN into work on a VPN connection, so I'm wondering if there might be a setting I'm overlooking.
Thank you for any assistance direction any of you can lend.
- Shuttle XPC SK22G2B V2 AMD Socket AM2 VIA K8M890CE
- AMD Athlon 64 FX-72 Windsor 2.8GHz 2 x 1MB L2 Cache Socket F
- VIA K8M890CE
- 4GB
- PCIE NVIDEA GeForce 6600
- On-Board
- 2x ACER AL2216W
- 1680x1050
- 2xWestern Digital VelociRaptor WD3000GLFS 300GB RAID 1
- Cable Modem
- Other Info
- HTC Touch Windows Mobile 6.1
