Low Physical Memory/ System Freezes
lechy
Hi guys,
My computer is hardly functional. I am experiencing very low physical memory, and my computer keeps freezing (that is the whole system freezes to the point where I have to turn it off and back on to do anything besides move my mouse). Programs also freeze and keep reading "not responding." My physical memory usage is hovering around 80%. This problem is only two weeks old, and I've had the computer for about a year and a half
Well you can close a few things in task manager that might help, but what I suggest you do for the moment is increase your page file usage. right click on my computer go to properties> advanced and then increase your page file. by rule of thumb it should be 1.5 times the size of your ram. so if you have 1GB of ram, then your page file should be 1.5GB or 1536MB
Install startup inspector as well. This lets you choose which programs you want to run at startup - this way you only need to run the process (or program) affecting your memory when you want to run it.
Startup Inspector for Windows - Free software downloads and software reviews - CNET Download.com
    Self built
    Q9550 overclocked to 3.93Ghz
    XFX 790i Ultra SLI
    (8Gb) - 2x2GB DDR3 Corsair Dominator Ram 1600Mhz + 2x2GB DDR3 OCZ 1600Mhz
    Asus GTX 280 + Gigabyte GTX 280 (SLI)
    Creative Soundblaster Fatality1 TY ultra Titanium
    3x24" BenQ, 22"Viewsonic
    1920x1200, 1920x1080, 1920x1080, 1680x1050
    2x 750Gb Samsung Spinpoint Raid 1 array 3x 1TB Western Digital
    Antec 1000W
    Gigabyte low end full-tower
    CoolerMaster V10 for CPU 7 120mm fans
    Logitech G9, G7
    Logitech Dinovo edge, dinovo mini
    24mb/s D/L 15mb/s upload - Telstra
    7 Fans - 3 fans integrated 4x case cut to fit and integrated into the case.
