See comments in text:
All I can add to this is the fact that:
1. My desktop & new laptop were both bought with VISTA HOME PREMIUM pre-installed.
me too
2. My desktop is hard wired to the router. (Never a drop out in 3 years) I do like VISTA.
3. My Belkin n router was recommended by DELL after the purchase of my desktop.
my Belkin router was recommended by geeky fellow from Best Buy, mine is the wireless network adapter and is used on Desktop with Vista pre-installed.
4. My laptop is only used wirelessly on my home network. It worked fine for the first few months, then the drop outs started. (All hardware is ok)
my desktop worked wirelessly for years using old network adapter provided by cable company. When connection started dropping (on old computer which used XP) everyone blamed network adapter. I first bought new adapter, which solved the problem, but a week later purchased new computer with Vista pre-installed. Again, it worked great, until this morning. Nothing has changed since last night. However, after the problem appeared, I installed some Vista updates which had been pending.
5. I did everything from every forum to solve it.
I'm getting close to that.
6. I am now typing on my old DELL XP laptop. (Same wireless connection) NEVER A DROP OUT.
I'm typing on my Toshiba Vista laptop on same wireless connection.
I will use this one as my portable, until 7 comes out, and then hop for the best.
