IHello, just upgraded to Vista x64 .Am quite impressed with it so far.After all the negatives I have heard about it, I was quite sceptical.Didn't need to be.Anyway, my question.
I turned off System Restore ,then thought seeing as I have the HDD space I may as well use it.I switched System Restore back on and thought no more about it. Now I notice there are no restore points.It should set a restore point at boot up and before installing software? It does neither and I can't find an option to turn it on.
Thank you
Thank you
- AMD Athlon 64 X2 4600+
- GigabyteGA-MA78GM-S2H
- 2 x Corsair 2GB Kit DDR2 800MHz/PC2-6400 XMS2
- 2 x WD2500AAKS Caviar SE 250GB 7200RPM SATAII/300 16MB Cache 1 X WD5000AAKS 500GB SATA II 7200RP
