You should upgrade or use an
alternative browser .
Solved Loss of restore points
I am loosing restore points and my tick to view more than 5 days box disappeared. Could someone please tell me how to resolve this.
39.3 KB
18.8 KB
Biostar
Biostar MCP6P-M2
NVIDIA GeForce 8400GS
CIBOX
Hitachi 160GB
Hello Brummy,
Do you dual boot with
XP ?
You may need to increase the
max disk storage size to allow for more restore points to be stored. Plus, I believe a restore point will only stay on your system for up to 90 days before automatically being removed as well.
Operating System
1TB Samsung 990 PRO M.2,
4TB Samsung 990 PRO PRO M.2,
Galaxy S23 Plus phone
Operating System
Hi Shawn,
I don't dual boot with XP, I have Max.shadowcopy storage is set at 7.7GB. Previously when that was set at 3GB I used to have more restore points and I did have that little box to tick for restore points more than 5 days.
I must tell you that I have done a Factory state restore a week ago(4/5/09). I think I'll let the system settle down a bit longer and see what happens.
Thanks for your help. Could you please mark this solved.
Biostar
Biostar MCP6P-M2
CIBOX
Hitachi 160GB
Ah yes, a factory restore would indeed wipe them out as well. I'm glad that you found the culprit.
Operating System
Operating System
