logitech quickcam E3500 woes....
skunksmash
im coming for cake
Hi all.....
i have my first ever problem with my rig!! :eek:
my dad gave me this cam b/c he could not get it to run on his XP rig, so i brought it home & installed it...
everything was fine, it worked perfectly for 2 days.
i then installed a new HDD & tried to transfer the program to the new drive :F, i couldn't... there was obviously some registry entrys that wouldn't migrate, so i left it on :C
then i tried to run it & it failed, i receive a Microsoft error stating.....''the application has stopped working''
so i though ok ...i have obviously corrupted the program files in some way, so i uninstalled it & tried again this time leaving it on the default :C drive, it installed, vista recognizes the cam & the drivers allow me to see the cam working at the end of the installation, but as soon as i close the setup it states the same error message...?? :sarc:
its quite perplexing, its fully installed & the device manager shows it as fully functional, yet it wont run.
i uninstalled it again & this time i hunted down any files pertaining to the cam & wiped them, then reinstalled....same thing :mad::mad: WHY!!! i know the cam works
it must have something to do with the new HDD, having to chuck this spanking new cam in the bin is really gonna annoy me
any help is much apprieciated..
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech cordless optical
    logitech EX110
    2mb
bump for an annoying problem!!!!! :)
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    logitech EX110
    2mb
Hi skunksmash,
I dont think this has anything to do with your new Hdd, it is most probably down to the uninstall leaving something in the registry that was corrupted, as you thought by you trying to move the program.
You need to uninstall again and use a good registry cleaner before trying to reinstall again.
Hope this helps
Pooch
    Self build
    Asus M3A32-MVP Deluxe
    8 gig Samsung PC800 RAM
    NVidia 9600gt
    AD1988b
    1680 : 1050 1280 : 1024
    Enermax Chakra
    Easy Line Laser Mouse
    Standard
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
