Little slow reaction from mouse movement
frank23
I just bought a new laptop HP Pavilion dv9925nr 4gb ram, athlon AMD Turion 64 X2 TL-60 / 2 GHz with NVIDIA GeForce 7150M Shared video memory (UMA) 1071 MB.
My problem is that theres a little late reaction from the point that I move the pointer of the mouse to actually seeing it move.
Dont know if its the graphics or what...
Help please.
    AMD Turion 64 X2 mobile techno
    4 GB DDR2 SDRAM
    GeForce 7150M Shared vi 1071mb
    250 GB - Serial ATA-150 - 5400 rpm
Go to Mouse settings -> Options for the pointer -> Make the precision of the pointer better (or something, my Vista version is in dutch).
    Intel Core 2 Duo E8400
    ASUS P5B-E Plus
    4GB Kingston ValueRAM DDR2-667
    ASUS EN8800GT 512
    Creative X-Fi XtremeGamer
    Packard Bell Maestro 190W
    1440x900 @ 75Hz
    WesternDigital 200GB 7200RPM + Iomega Desktop HD 360GB 7200RPM
    Xilence Power 600W Gaming Edition
    Coolermaster Centurion 534 Black
    Standard Coolermaster Case Fans + Standard Intel CPU Fan.
    Razer Copperhead Tempest Blue
    Logitech G15 V1
    100.0 Mbps
What my dear friend here was trying to say was check the box for Enhance Mouse Precision as follows:
To get there, it depends on your system. If you are using the Classic Control Panel then go to Control Panel --> Mouse --> Pointer Options tab and check the box.
If you are using the new Control Panel, then open Control Panel --> Hardware and Sound (you might can skip this step - 3 links under Hardware and Sound on my machine is Mouse) --> Mouse --> Pointer Options tab and check the box.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
ok, that is on already.
When i start the start menu, and pass the pointer of the mouse through the icons (all programs, control panel, computer, network..) it has a late action, for example:
when the pointer of the mouse is going up, the shade of the selection of the pointer on the start menu is late, it has a little lag, it doesnt match with the pointer.
Its like if the computer is slow, but its not.....
    4 GB DDR2 SDRAM
If it is a wireless mouse try replacing the batteries....
wait, are you talking about the point stick / touchpad built into the laptop?
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
nop, I have a wireless mouse, logitech. I tried changing the batteries but nothing, still the same thing.........
    4 GB DDR2 SDRAM
Wireless mice eat up batteries. Are you sure the new one's are fully charged and not old ones just laying around? Also, make sure there's a direct line of sight between the receiver and the mouse. Lastly, give that USB port a good reaming.
    Fumz' Flux-Capacitor
    E8400
    DFI LP DK P35-T2RS
    4GB G.Skill PC-1066
    eVGA 8800 GTS
    X-Fi XtremeGamer
    Samsung 226BW
    500GB W.D. RE2 Primary 1TB W.D. Caviar GP WD10EACS
    Lian Li Lancool K62
    Logitech G5
    2.5MB/430
    D-Link DGL 4500
I know this thread is old but I really cant find a solution on my problem.
I have the exactly same problem. It is not the batteries for me atleast. Ive tried with a razer lachesis aswell, just to be sure. I run logitech MX5500 keyboard/mouse. Vista home x64.
This is really driving me crazy because my accuracy is simply none exsisting. I dont know about the one who started this thread but my keyboard is behind aswell, its easy to see when I just press one letter down and release it takes maybe 0.5-1sec before it stops.
I have updated everything that is possible to update(I run logitech software programs). I have system restored, wiped vista and reinstalled all the time with the same problem.
Well if someone has a solution for this problem I would be very happy :)
