Lineage 2 (Interlude) Problems
kislama
I have a problem with starting Lineage 2 Interlude on Windows Vista Business x64.
After Windows install, and after updates, i installed the Lineage 2 Interlude client and worked at well.
BUT after Directx update the client crashed, with this error message.
After this message, the client is started but i can't log in. (Access failed...)
Three reason what may be the source of errors:
- DirectX (redistributable, the newest)
- .Net Framework (2.0 or/and 3.0)
- Visual C++ 2005/2008 Redistributable package x64 (once with 2008 x64 package the client is worked, after Windows restart the problem is was the same).
I can't find a solution of this problem yet, if anybody have idea please share with us. :)
Thx
Paul
    Intel Core Quad Q8200
    MSI P45 Platinum
    ASUS EAH4870
if you have not already then i would suggest manually downloading the latest Directx update and try installing again.... oh and also try installing the update as administrator too
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    Realtek 7.1 CH HD Audio
    1280x1024 + 1360x768
    Thermaltake W0133RB 1200W PSU
    Antec 900
    Stock + Antec 900 case fans
    Logitech MX Revolution
    Logitech G15 (full layout)
I'm runned L2 as Administrator, and the DirectX (2008 August, now i will try the November) was the manual install version :)
But i will try again, never give up :D;)
    MSI P45 Platinum
    ASUS EAH4870
I found one solution for this problem, and now with "small errors" the Lineage client is running :)
    MSI P45 Platinum
    ASUS EAH4870
would you be so kind as to share your solution methods with us for anyone with a similar problem :geek:
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    Antec 900
Sure I write it, sry
1. Install Windows Vista x64 (Business what i use).
2. Turn off UAC (not the lucky, but worked).
3. Install all Drivers (Lan, Audio, Video).
4. Install Service Pack 1 (manually, not with Windows/Microsoft Update).
5. Now install all update with Windows/Microsoft Update.
6. Install DirectX 2008 november (End-User).
7. Install Lineage2 Interlude.
One more little thing: Lineage running only when I started in Computer, and I search in the Lineage2 System folder the l2.exe. (with e.g. Total Commander or with Short cut dont't work)
This is worked for me.
    MSI P45 Platinum
    ASUS EAH4870
