LAN Problem
Hello SudhirKam, welcome to the Vista Forums :party:
Could you please give some more information,
What Hardware is involved?
Wired, or Wireless?
Are any messages shown?
What have you tried?
If you can post back with more details I'm sure someone will be able to help :D
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Samsung 32" TV
    68 MB Down 18.5 MB Up
Yep. Thanks for the response. Its a wired network. I got vista starter installed in my system. And then I tried to install the drivers in my system. I got response from all the drivers installed, except the LAN Driver. LAN driver which i installed now is not getting supported with vista OS. The LAN which i installed was Realtek GBE & FE Ethernet PCI NIC Driver. Will this information be helpful to solve the problem?
Hi Sudhirkam,
What is the make and model of your motherboard?
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    Samsung 32" TV
Hi SudhirKam,
Here is a link to the HCL website: hcllaptops.com. Have a look at this and see if you can identify your system here. Note that HCL don't appear to actually manufacture systems, rather they are a retailer.
    Gigabyte IF233
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    Samsung 32" TV
