Key trouble - Reinstalling
Tarak
I was going to re-install Vista using the upgrade disc by Microsoft
But when i checked the key at the bottom of my laptop, it is XXXXX-XXXXX-XXXXX
But when i downloaded keyfinder.2.0.1 something like that
They key was different
What to do.
I am reinstalling what should i put in as a key?
Thx
Take a note of both.
I would use the one provided on the bottom of your PC.
Have you performed any anytime upgrades/activated via phone?
If in doubt try both.
Oli
    Apple MacBook, 5,1
    Intel Core 2 Duo 2.4Ghz
    4GB DDR3
    Nvidia 9400m
    13.3" Apple MacBook LCD Screen + 22" HannsG DVI LCD + 21.5" Samsung USB Lapfit Monitor LD220
    1280x800 + 1920x1080 + 1920x1080
    SATA Internal 2.5" 500GB (305GB HFS+, 195GB NTFS) External USB 3.5" 1TB (HFS+)
    Aluminium Unibody
    Apple Magic Mouse
    Apple Late 2009 Wireless Keyboard (US)
    6.33Mb/s up. 0.36Mb/s down.
    Harman Kardon Soundsticks II Speakers
Then you've got two install keys :s.
Count yourself lucky.
Just pick one and put the other in a safe place.
Oli
    Apple MacBook, 5,1
    4GB DDR3
    Nvidia 9400m
    Aluminium Unibody
    Apple Magic Mouse
Oli
So i have 2 keys
If i m re-installing vista back to vista, i can use the key that came when i bought this laptop
The 2nd key, back on my laptop, can i use that to upgrade to win 7....
I am clever i know,..... jk:p:p:p:p:p:p:p:p:p:p
helpers help me
No, the second key can only install a specific version of Vista (eg Vista Home Premium 32bit) and most certainly can't install Seven.
Oli
    Apple MacBook, 5,1
    4GB DDR3
    Nvidia 9400m
    Aluminium Unibody
    Apple Magic Mouse
It is normal to have a different key on the HD with an oem preinstall.
You can't use the key off the HD , unless you also retrieve the activation cert that goes with it.
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
Exactly what I was about to say.
Use the Key which is on the sticker of your laptop.
If you are re installing make sure you install the one with SP2 in it.:D
That should save you the work of downloading SP2 via Windows Updates
    HTPC/Desktop PC/Gateway LT2104u
    Intel Pentium 4 2.8Ghz with HT/3.0Ghz with HT/Atom N450
    GIGABYTE GA-81915ME-C/Intel D865GBF/Acer LT21
    2x1GB DDR 400Mhz/512x2GB DDR 400Mhz/1GB DDR2-800Mhz
    ECS 9800GT 512 DDR3/ Sapphire HD3650 AGP 8x 512MB/Intel 3150
    Turtle Beach RIVERIA 5.1 SPDIF Out/SoundMAX AD1985/Realtek H
    SONY BRAVIA KLV-32V300A V-Series/ KLV-19T400A/ Built-in
    1920x1080/1980x1080/1024x600
    MAXTOR 40GB WD ESSENTIAL EDITION 1TB USB Hitachi HDT721010SLA360 1TB SATA 150/ 250GB Toshiba
    OCZ Fatal1ty 550W/
    Lian-Li v351, Lancool K-62 DragonLord
    Logitech Combo
    Logitech Combo
    512 Kbps
