K7 antivirus problems
Boboflargen
Let's keep this brief:
I downloaded the free trial of K7total security and liked it, so I decided to read some reviews to ensure its quality, and there after I bought it. After buying the full version I was offered a download to install the full version.
No problem, but what I did next only makes sense because I did it after work at around 1 in the morning... technicall today.
What I did was delete the K7 folder from my program files, but now when I try to install K7total security the full version, some hidden part of k7total security from the trial version says it is still in my computer. I went to uninstall the program from control panel> uninstall programs list, however when I try to uninstall K7total security it says that it can't find the program, which makes sense because I deleted it, but then afterward it still remains on the uninstall list. And I still can't install the full version...
The message looks the same no matter what I do.
file 'C:\ProgramFiles\K7
computing\K7TSecurity\Common\K7TSSettings.dll' can not be found.
Make sure the file is on target system or installed already.
So I turned off the computer and decided to deal with it in the morning,
and here i am. Any help would be appreciated, as I cannot find any related articles on the problem I am having. Thanks.
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
sees man first install the demo version which you had earlier.so when you will install that then the needed files also will be installed. then you can normally uninstall.this os the right way too because it deletes the registry files. hope it is useful:D
    Compaq
    intel 965 chipset family
    2 GB DDR 2 SD RAM @ 667 MHz
    On board upto 358 MB RAM
    15"
    160 GB WDC
