JMicron Driver difference
mourningstar625
I have a gigabyte board with a jmicron controller and there is 3 different driver packages available, the normal one, ESATA, and write cache disabled. Obviously the write cache disabled is self explanatory but whats the different in ESATA and regular? May sound stupid but ill go ahead and ask
Found this on the JMicron site.
It's not real clear, but....
JMB36X (360/361/363) RAID/AHCI Driver Release History
// [Package Description]
// RX.XX.XX - Driver would get eSATA setting from BIOS/Option Rom.
// RX.XX.XX_eSATA - Driver would report all Device connected as Removable Device with WriteCache Enabled.
// RX.XX.XX_eSATA_WriteCacheDisabled - Driver would report all Device connected as Removable Device with WriteCache Disabled.
// RX.XX.XX_No_eSATA - Driver would report all Device connected as Fix Device.
    ~76
    Intel Core i5-3570k 4.6GHz
    Gigabyte GA-Z77X-UD3H, SATA 6Gb/s USB 3
    8GB DDR3 1600 CORSAIR Vengence C8 1.5v
    Sapphire HD 7770 Vapor-X 1GB DDR5
    Realtek HD Audio ALC889 Integrated Chip
    22" LCD Dell SP2208WFP
    Samsung 840Pro 128GB SSD, Seagate Barracuda 500GB SATA2 7200rpm 32MB cache, Seagate Barracuda 1TB SATA2 7200rpm 32MB cache,
    Corsair HX650W
    Cooler Master Storm Scout
    Corsair H80 w/12cm fan, 2x14cm 1x12cm case
    CM Sentinel
    Logitech Wave
    Speed is not the word I would use to describe it!
    eSATA ports, External eSATA Seagate 500GB SATA2 7200rpm, External USB WD 500GB
Thanks a lot for the useful info.
Your most welcome, glad I could help.
The site is here:
http://www.jmicron.com/Driver.htm
Click ‘Download’ at the bottom of the page
Click ‘jmb36x’ for the RAID drivers
Click ‘Win2k_xp_Vista’ or your OS
Click ‘ReleaseNote.txt’ for above info and release history
Then select the driver you prefer.
    ~76
    Corsair HX650W
    CM Sentinel
    Logitech Wave
