Lorien, I too tried your steps and to no avail. I dont know how to post a screenshot, but the message basically says that it cannot locate itunes. When I try to uninstall so that I can reinstall or repair it, I get a Window Installer screen that says "The feature you are trying to use is on a network resource that is unavailable"
"Click ok to try again, or enter an alternate path to a folder containign the installation package iTunes64.msi in the box below ...and then there is a browse box but of course, I cannot locate the itunes 64.msi file. So to summarize, I cannot install, uninstall or repair itunes or quicktime... I have downloaded both SISoftware and UNIBLUE REGISTRY BOOSTER...and both did not help.
I would appreciate ANY other suggestions you may have.
Thanks in advance,
Susan
Thanks in advance,
Susan
- hp Pavilion DV-1448ca
- AMD Turion X" Dual Core Mobile 2.2
- ATI Radeon HD 3200 Graphics
