itunes and printer
toskala16
hello people. i need to no some stuff about itunes. I might upgrade to windows vista and i think my itunes library might be erased if i upgrade to windows vista so can someone help me out. i usually download music off limewire and my itunes library is very organized. i was thinking of doing an upgrade installation.
the 2nd thing is that i have some printers dell photo 626 and samsung ml-1740 series and would i have to install these printers again becuz i dont no were the installation cds are so ya. someone please kindly help me out
momin:)
With regards to iTunes, assuming you have XP, you’ll need/want to backup one, possibly two folders.
The first is your “My Music” folder in “My Document” as that’s where your iTunes library database file stored - even if your main iTunes music folder (where your actual music files are downloaded/installed) is located elsewhere. If you do have your music folder located on the same drive, back that up as well.
Personally I’d recommend you put the actual Music folder on a separate HD and keep a current backup of the “Music” (Vista)/”My Music” (XP) folder in a safe place. I would also recommend backing up your actual music folder.
Some useful info - when you do a Vista update/install, Vista will create a folder called “windows.old” and put your XP contents there. (backup anyway!!! just in case!) Once Vista is up and running you can go in that folder and copy/move contents as you wish, than either keep, or delete the folder through “Disk Cleanup”
Before upgrading to Vista I’d advise you to run the “Upgrade Advisor tool. This will point out any potential software/hardware problems when moving to Vista. You can get it here - Download details: Windows Vista Upgrade Advisor, or if you already have a Vista disk, you can run the program from it.
I would also advise you look to see if your printers have vista compatible drivers.
You’ll also probably want to check out this tutorial on installing Vista upgrade - http://www.vistax64.com/tutorials/68767-clean-install-upgrade-vista.html
Hope this long winded explanation helps
Good luck
    Intel D975XBX2
    ATI Radeon HD 4890 (1GHz)
    hp w2207h (22" widescreen)
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
    Logitech MX Revolution
    Logitech Wireless Wave
thanks alot sygnus21 for your help. i was very confused but you have really cleared my mind. :). Also i will look for drivers for my printers and take ur advice
once again thnx alot:D
momin
