You should upgrade or use an
alternative browser .
ok. if u download a file. just say lunix and u wanna install is. do i have to burn it.
i downloadded it it is a iso file
so can i just plop it in
restart
and boot in it. in my case esc an
and click dvd drive
and it will instlll?
amd 64x2 4200+ 2.2ghz per core
ECS NETTLE
3 gb
nvdia 6150se nforce 430(old rig, upgrading)
reltrek hd audio
hp w1907
1440x968/1024x768
320gb
upgrading, Coolmax CA-450 450watts
hp casing
defult..
hp
hp
768kbps down and 128 up...very slow..
not great compared to other people..
Hello Kiddieboy,
Yep, you can burn the ISO file to disc first using a image burning program like
ISODisk . Afterwards you should be able to use the burned image disc to install it.
Operating System
1TB Samsung 990 PRO M.2,
4TB Samsung 990 PRO PRO M.2,
Galaxy S23 Plus phone
Operating System
i dont want to waste dvd like that. can i burn it on m hard drive then format it so it is a live system format. like a usb drive and then boot from it. then later delete it. so i dont waste a disk
ECS NETTLE
3 gb
reltrek hd audio
hp w1907
1440x968/1024x768
320gb
hp casing
defult..
hp
hp
Operating System
Operating System
