Is there a decent ISO image mount utility out there?
MrBiggz
Greetings!
I used to use Virtual CD from slysoft. It doesn't work with Vista :(
a) Is there anything in Vista that can mount an ISO image?
or
b) A cool app that will let you mount any number of images and re-mount them upon start up.
I've tried a couple and no success :(
Regards ...
    Intel Core 2 Duo E6750 @ 2.66Ghz
    Abit IP35 Pro
    4Gb Patriot PC1600
    EVGA (Nvidia) GT 430 1GB
    On board
    Syncmaster 2494
    Windows 11 Workstation
    Ryzen 9 5950X
    Creative
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Logitech Performance MX
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
i use ultraiso, works under 64 bit vista ultimate
    intel core 2 quad Q9450
    gigabyte EP45-DQ6
    8gb Gskill PC6400
    Visiontek Radeon 4870x2 2GB
    X-FI fatality FPS 7.1
    Viewsonic VG2230wm
    1680X1050
    VelociRaptor WD1500HLFS 150GB 10000 RPM, WD CAVIAR black 750GB
    Antec TruePower New TP-750 watt
    Cooler Master HAF932
    XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
    comcast 16mb\second
daemon tools pro works fine in vista 64 and will let you mount 2 virtual IDE drives!!
Yup, I second that one. Worth the small fee and is constantly updated and improved upon. The licence renewal is a bit of a pain each time a new version comes out...quite frequently..but there are help topics on Daemons forum.
    Dual Core E7200
    Asus P5K
    4GB DDR2 800 SDRAM
    GForce 8600GTS 512mb
    Auzentech XFi Prelude 7.1 on Onkyo605 Rxer
    20" Samsung SyncMaster 206BW
    Sky UK
i use PowerISO win X86 great progy
And up to 8 drives!
Daemon tools free version also installs some crapware but is in essence best suit3ed for running images of protected CD/DVD games. Alcohol 51% is the free version of Alcohol 120% but I think Alcohol is quite detailed and has (too) many options for normal use.
POwerIso has the advantage that it can also be used to make ISO-images and read the .daa format that is often used. All other can't...
I went with the Daemon tools free version. I just didn't choose to install those two search items. Keeps me from searching for Disk #1 to play games! =)
Thanks for the help! I'm still going to take a look at the other suggestions too! :)
    Abit IP35 Pro
    4Gb Patriot PC1600
    On board
    Syncmaster 2494
