Is possible to prevent regular Users account From Ejecting usb?
Stuckfree
Regard.
    HP
    2 G
    HP
    2 G
    AMD
    REALTEK
What does "ejecting usb" mean?
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Hi Wither3,
Hi man, I mean safely remove your usb by right clicking on the usb icon and select the remove safely this device or something.
Thanks.
    HP
    2 G
    HP
    2 G
    AMD
    REALTEK
Hi Brink- That's a lot of information to digest.
I'm wondering what exactly Stuckfree is trying to accomplish. It appears he wants to prevent a user from doing something.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Hello Stuckfree,
I suppose that you could disable write caching for the USB devices for quick removal to no longer need to use Safely Remove Hardware to eject them.
Write-Caching - Enable or Disable - Windows 7 Help Forums
Hope this helps, :)
Hi Brink,
Thanks for the link, after reading the information from my understanding the quick removal option main benefit is if a flash drive were to be accidentally pulled out of its port, the data being written to it is much less likely to be lost that doesn't prevent any regular user account from ejecting the usb and I mean the eject option in the usb icon right click menu still works fine even though the quick removal option is selected by default for usb devices.
Actually is there a group policy which can prevent ejecting usb devices on the usb right click menu? So far I tried the Devices:Allows to format and eject removable media group policy by selecting only administrators account can only remove removable devices but doesn't seem to work.
Regard,
Thanks.
    HP
    2 G
    HP
    2 G
    AMD
    REALTEK
I'm not aware of one. :(
Hi BRINK,
That means restricting from ejecting a USB from group policy is almost impossible because there's no such options right?
Thanks.
    HP
    2 G
    HP
    2 G
    AMD
    REALTEK
Correct, I have not seen one for that.
Hmmm, I wonder if it's an attempt to use a USB as a "dongle?"
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
I have never hears of a means of restricting access to the USB eject button. I expect the reason is - what useful purpose would it serve? It isn't a security measure because anybody with physical access to the computer can remove the device at any time.
If you could explain why you want to do this we may be able to help.
