Solved Irql not less or equal
Derwin
Hi, I been trying to solve this one myself for a couple of weeks, having run memtestx86 I replaced the RAM, and the PSU noticing the fan was labouring. Aswell as did a clean install of Vista. Computer works fine in 2d desktop mode, GPU temp was running a little high, so installed EVGA Precision to bring the temp down. But the I still get BSOD while playing World of Warcraft after a few minutes, yet I have played GTA: Vice City without any problems. Old StarCraft does crash as well but only after like 20 mins of play.
(no I'm not blaming Blizzard on this lol) Anyway I'm attaching my reports hopefully you guys can help me figure out what needs replacing or just re-configuring. (fingers crossed for the latter)
Vista Home Pre x86 32bit
Mobo: asrock n68c-s ucc
Video: BFG Nvidia GeForce 9800GT
Sound: Soundbalster X-Fi
RAM: 2x2 GB of Kingston ddr2 667
Also is there any software you could recommend checking the integrity of the Video RAM or Processor? And would give a report even if it does cause another BSOD.
    Home Built
    AMD Athlon 64 X2 Duel Core 6000+ 3.11
    Asrock N68C-S UCC
    2x2Gb Kingston 4Gb total
    SB X-Fi Xtreme Audio
    Samsung 943
    1360x768 native
    ST350032 0AS SCSI actually its SATA not sure why it reports as SCSI
    Thermaltake TR2 500W
    Shiny Black
    2 Large side and rear
    Logitech Laser
    Logitech USB
    4G tetherd
    Computer works fine in Desktop mode and 2d Games Crashes on 3D or full screen games, except while playing GTA Vice City? and i had the settings turned up high, no lag or stutter. weird crashes playing World of Warcraft and StarCraft
Usually, this kind of problem is caused by GPU and/or CPU overheating. You could download HWMonitor or any of the other monitoring software and check it while you're playing.
When you get a BSOD, down at the bottom above where the countdown is going on, it usually states the faulting problem. Do you know what it says?
I'm asking because it's a lot of work going through all the log files.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    40 Meg
Hey it appears to be fixed, I removed the CPU cleaned the heat sink and fan and applied new thermal paste. Haven't had a BSoD since. Thanks guys!
    Home Built
    Asrock N68C-S UCC
    Samsung 943
    1360x768 native
    Shiny Black
    Logitech Laser
    Logitech USB
    4G tetherd
You're welcome. Cleanliness is next to godliness when it comes to cooling GPU's and CPU's. It could have been the thermal paste also.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
