IP help
By this I'm assuming you want to change your LAN connections IP Address.
To do so enter network and sharing center and from the left hand side click "Manage network connections"
A new window will pop up, right click on "Local Area Connection" and select properties.
Another window will open, from the list find "Internet Protocol Version 4 (TCP/IPv4)" then click Properties button.
You can now set a manual IP Address.
It might be useful to provide some info on why you need to do this, is it to solve a problem you currently have?
It's usually better to stick to getting your network address from a DHCP Server.
    2x AMD FX-74 @ 3.0GHz
    ASUS L1N64-SLI
    4GB OCZ Reaper DDRII
    2x BFG 8800GTX OC 768MB (SLI)
    Creative X-Fi Fatl1ty
    HP L2045w
    2x 500GB Samsung T166 SATAII
    Enermax Galaxy 1000W PSU
    Thermaltake Armor Extreme Case
    Razer DeathAdder
    Microsoft Multimedia Keyboard
    8Mb ADSL (UK Online)
Is there a way to change my IP address? I have vista HE 32bit:cry:
By normal means there isn't a way to change the IP address your ISP gives you. You can however, use whats called a proxy server (or anonymous proxy) to tunnel to the remote IP and use it. If you were to tell us waht you are trying to do we could help
Ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
Most ISP's providing a home connection distribute their IP's by DHCP, so turning off your router for a few mins and back on may cause it to grab a new IP from your ISP's pool of addresses.
    ASUS L1N64-SLI
    HP L2045w
    Razer DeathAdder
Most ISP's providinga home connection distribute their IP's by DHCP, so turning off your router for a few mins and back on may cause it to grab a new IP from your ISP's pool of addresses.
True, In theroy. If dynamic Host Config Proto. is used and he turns off his router his current IP becomes free and the dhcp server may very well assign the newly released IP right back to the OP. My isp (time warner) uses dhcp extensively and every time I flush my dns, reboot my router or renew a lease I get the exact same IP. I think the device that serves my area has its own pool of IP's so the only way you can be sure to get a different IP (like for surfing bad web sites) is by either using openDNS, or proxies to get an IP thats assigned from a different pool.
Ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
I am doing this b/c I am having problems gettin into a staryburyplus chat..I am a mod and someone has hacked in to it, and I can not get in it..So what is easiest way to do this
If hacker has changed uid and pword, IP change will not help you unless your current IP is being barred. If you are a mod, who is admin? cant the admin go into your account and reset the uid and password?
Ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
Stephon Marbury is the admin...The hacker has done this to alot of people..Just cant fig it out!
So your saying the admin has lost access to his account as well? Who hosts the server? cant they restore from backup to kill the hack? Im willing to help but need a ton more info
Ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
No Stephon has no problem its us mods and chatters, Justin.tv is where it is at, and there is no working number for the site..HELLLLLP
OK I have created an account and emailed the help/support about it. why cant you do the same. They dont even check the email for validity. Im still not sure what the problem is. If you create a different account and email justin.tv that your mod account has been hacked and to please reset the uid password it should clear your account. then by re logging your mod account you will have mod privledges.
Ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
