Involuntary sleeping mode.
This problem looks more of
  • Laptop
    Votes: 1 100.0%
  • vista o/s
    Votes: 0 0.0%
  • display card
    Votes: 0 0.0%
  • Total voters
    1
vikas.rane
Hello everybody,
I am looking for some help for my unusual problem with vista. I have vaio with vista home premium installed on it. My laptop goes into sleep mode involuntarily, anytime while working on it. What i have observed is, this normally happens when i am trying to type on my laptop keyboard, All of sudden it goes to sleep mode and i have to press enter to get it back. The frequency of this unusual behavior has only increased by time. I have already installed the latest display drivers, I have also reset my Bios to default setting. Nothing seems to be working.
Had anybody heard or faced this kind of problem before. If so please help me out.
Thanx in advance.
Vikas
Hi Shawn
Thanx for your immediate feedback. But what i like to share more is i face this problem even when my sleep, hibernation and hybrid sleep options are turned off completely. I wonder is their any inbuild shortcut key for sleep mode which i might be accidentally hitting it while typing. just an wild guess.:confused:
regds..vikas
don't want to annoy anyone here but where is your sleep button you may be pressing it accidentily i had a problem similar to that until i just disabled the feature.
sorry in advance if this is not the problem
posted at the same time sorry
    me
    intel Q6600 @3.0Ghz
    gigabyte EP35C DS3R
    8 GB OCZ 1066 HPC REAPER
    Sapphire 4870 HD 1024mb gddr5
    lg flatron 20.1
    western digital 350gb samsung spinpoint 120gb
    900w
    thermaltake aguila
    2x 120mm 2x 10cm
i too think i might be hitting some wrong button. I have a vaio cr series laptop purchased in canada, all my buttons have English and French alphabets on it. I am just unable to find the button assigned for SLEEP mode. If you can guide me where is this button on vaio for sleep, it might be helpful or just let me know how did u disabled it on u r system.
thanx in advance
the tutorial that BRINK put a link too should direct you to it otherwise it's in contol panel/ power options /sleep mode, on my computer it is a side option it may be different in yours however you can disable it there or if that option is not there change how the button reacts when pressed (not an option on all computers)
the key would have a primary use but may be highlited with a couple of zzz to indicate a sleep function.
your sony vaio may have onboard applications which help control these.
    me
    intel Q6600 @3.0Ghz
    gigabyte EP35C DS3R
    lg flatron 20.1
    900w
    thermaltake aguila
    2x 120mm 2x 10cm
Vikas,
I do not know if this is the same for you exact model, but I found a keyboard layout link that may help. You might be pressing keys 9 or 10. You may also have 10 set to sleep instead of shutdown.
VAIO
This tutorial will show you how to change what action (sleep or shutdown) the case power button will do when pressed.
http://www.vistax64.com/tutorials/68146-power-button.html
