Internet Problem
saurabh157
I have been having some problems with my net connection. it drops out
every now and again. I can't access net but still on local LAN network.
This problem is with the new Laptop I have bought which has Vista Premium pre
-loaded.
When I click on net icon in taskbar (open network n sharing center), it shows
multiple networks (2-3 networks..named network, network 2, network 3) and my
guess is that they are confusing the system, which one to use for internet.
I have also tried merging all 3 using the customise option available for each
above network, but the internet still doesn't work.
In "Network Connections" options, I just have a Local Area Connection and a
Wireless connection.
Any help would be much appreciated.
Cheers,
Saurabh
saura
go into device manager by typing that is search. look for the networking tab and look to see if your device is there and woriking properly. If it ins't there or has a yellow triangle it means the driver isnt installed correctly or is the wrong driver
te; us what the results are
ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
I think if you have more than one network it will use one of them anyway but it may be cause of internet setting or something try to disconnect one of them and try again:D
    Toshiba Satellite M300
    Intel core 2Duo
    2.00GB
    ATI Mobility Radeon HD 3470
    Conexant High Definition SmartAudio
    Generic PnP
    silk
    Synaptic PS/2 port touchpad
