Internet Explorer problems
almost
Hi! This is my first time in this forum. So forgive me if I'm in the wrong area...but need help. Internet Explorer keeps "stopped working" and "restarting" while I'm in the middle of doing things. I lose all my open windows/tabs. Can someone please tell me if there is a solution to this problem. Also, how do I find out which Vista version I have?
Welcome almost, Click on the lower left Vista windows logo start button and then click on "Welcome Center" or type Welcome Center in the search bar.From there it'll tell you what version of Vista you are using...and everything else.
As far as your other problem I'd try
going to Internet Options-> Advanced and first choose "Restore Advanced Settings" and then click "Reset". Restart IE. I f that doesnt work i'd also do a spyware and virus scan.
Cheers,
    AMD Athlon 64 x2 5200+
    Asus M2N-SLI Deluxe
    4.00 GB Kingston ValueRam
    HIS Radeon HD 4650 1GB 128-bit
    Creative Sound Blaster A-SE 7.1
    Asus 24" & Dell "19" (dual)
    1440 x 900 & 1024 x 768
    Seagate Barracuda 320 gb Seagate FreeAgent 1tb external drive Seagate FreeAgent 500gb external drive
    Rosewill 750w psu
    XCLIO Windtunnel case
    ARCTIC COOLING Freezer 64 Pro 92mm CPU Cooler
    Logitech LX7 Cordless Optical Mouse
    Saitek blue lit keyboard
    over 2mbps T2
