Internet connection sharing problems
Rep0o8i
Hey, well i use ics for my xbox 360 live but i have a problem, sometimes it screws up, to make it work i got to.
turn off my xbox 360
turn off ics
disconnect from internet
turn on ics
then connect to the internet
then turn on xbox
then reset xbox network settings to default (re-setting the ip's)
it works fine after that but its REALLY annoying, i have a dynamic ip
uhh my setup is like this
if im suppost to go threw all that crap for xbl then please tell me :)
uhh im also on talktalk broadband if that makes a dif
    xp
