SomePsycho
I've got a:
Vista Home Premium 64
Intel Core2 Quad 2.4ghz
3gb ram
Nvidia GeForce 8600GT
I have an intermittent slowing issue. Sometimes on system startup, the computer will be running very slowly, as though there is a huge drain on system resources- taking 10 seconds plus to open IE, for example- but when I open the task manager and take a look, I'm never using more than 10% CPU (its usually more like 4%) and physical memory is usually around 30-50% used.
This problem can persist through a reboot (where the system will appear to hang on the "Shutting down..." screen for up to 10 minutes), but through a restart or two I can usually get it to go away.
Any possible fixes out there? Thanks in advance!
3gb ram
- Intel Core2 Quad 2.4ghz
- 3GB
- Nvidia GeForce 8600GT
