Solved Intellitype Pro 8.2 Keeps Crashing
Ex_Brit
If you're going through hell, keep going
Just lately itype.exe stops working within seconds of booting up, tries to restart and then stops again and I get the 'Close Program' choice. This has been an intermittent issue over the years in all flavours of Windows with just about every version of the software and I have never found solutions anywhere despite exhaustive Google searches. Has anyone any ideas as to why it suddenly starts to happen out of the blue? It would appear that Microsoft know about it but aren't doing anything about it and it's such a rigmarole using their support maze.
Microsoft Wireless Entertainment Keyboard/Mouse 8000 Desktop Set, software version: ITPx64_1033_8.20.469.0. Mouse (and camera) working fine as does the keyboard but none of the special keys work as a result of this. I've tried uninstalling/reinstalling. I'm mystified why this suddenly starts happening.
Here's the Event Viewer entry (one of many)
Log Name: Application
Source: Application Error
Date: 24/12/2011 7:38:35 AM
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: R2D2
Description:
Faulting application itype.exe, version 8.20.469.0, time stamp 0x4e41c954, faulting module kernel32.dll, version 6.0.6002.18449, time stamp 0x4da47b2f, exception code 0xe06d7363, fault offset 0x00000000000170cd, process id 0x19a8, application start time 0x01ccc238f35ef0ab.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2011-12-24T12:38:35.000Z" />
<EventRecordID>39318</EventRecordID>
<Channel>Application</Channel>
<Computer>R2D2</Computer>
<Security />
</System>
<EventData>
<Data>itype.exe</Data>
<Data>8.20.469.0</Data>
<Data>4e41c954</Data>
<Data>kernel32.dll</Data>
<Data>6.0.6002.18449</Data>
<Data>4da47b2f</Data>
<Data>e06d7363</Data>
<Data>00000000000170cd</Data>
<Data>19a8</Data>
<Data>01ccc238f35ef0ab</Data>
</EventData>
</Event>
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
Try replacing the batteries in your keyboard.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
They are brand new rechargeables. But that would have no effect on the software surely?
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
That link was dealing with a slightly different problem from mine and these batteries are new anyway so it can't be that unfortunately. One user in that thread mentioned Windows Defender blocking things so I even tried making an exception for itype.exe in WD, no effect. I had already searched the web high and low regarding this as it isn't the first time it has happened and not just with this keyboard either.
I suspect it's a software clash in Windows but with the Event Viewer giving absolutely no hint of what might be to blame it's a mystery.
I can still use the keyboard of course but certain peripheral keys are non-functional without the software being active. It's just an annoyance more than anything else. I'm sure it'll clear up eventually.
Thanks for your suggestion.
Edit: I multi-boot and it isn't happening in any other OS, Vista or Windows 7.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
Are you sure that it is compatible with 64-bit?
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
It comes in both 32 and 64 bit versions and the website tells me to download the 64-bit one only.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
Besides, it works OK in my other Vista and Windows 7 installations on the same machine.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
OK guys. I realised that the software version in my other OS's was the one previous to this, so I uninstalled IT 8 and installed IT 7 and all is working fine. Buggy software I guess.
Thanks for your help. At least it got me really troubleshooting this thing instead of putting up with it.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
Kinda puts a twist on that inscription under your name- older but not wiser. Glad it's working.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
LOL. All the best. ;-)
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
