plaintastic
This has been happening for the past three days. I just recently bought a laptop, the Toshiba Satellite A305-S6898, with Intel® WiFi Link 5100.
I would be just surfing on the internet and then the WiFi link would randomly just stop working. I would go to the available connections window, and the network i'm connected to would say 'Connected with limited connectivity', and then it would disconnect and then it would not be able to detect any networks, even though it previously did before. I know it's not a network problem because the same problem occured on two different networks I have set up in two different places. The device manager does not report anything wrong with it, and I did not randomly turn off the wifi for any reason. I would have to reset my laptop in order to fix the problem.
Microsoft Windows [Version 6.0.6001]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Owner>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : ******-PC <---i personally blocked that out.
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) Wireless WiFi Link 5100
Physical Address. . . . . . . . . : 00-21-5D-74-13-0E
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::2d9b:2e89:e0b8:2d2a%11(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.10.3(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Sunday, December 07, 2008 2:19:10 PM
Lease Expires . . . . . . . . . . : Monday, December 08, 2008 2:19:09 PM
Default Gateway . . . . . . . . . : 192.168.10.1
DHCP Server . . . . . . . . . . . : 192.168.10.1
DNS Servers . . . . . . . . . . . : 192.168.10.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . : access.bestbuy.com
Description . . . . . . . . . . . : Realtek RTL8102E Family PCI-E Fast Ethern
et NIC (NDIS 6.0)
Physical Address. . . . . . . . . : 00-1E-33-69-17-D3
Tunnel adapter Local Area Connection* 6:
Description . . . . . . . . . . . : 6TO4 Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 7:
Description . . . . . . . . . . . : isatap.access.bestbuy.com
Tunnel adapter Local Area Connection* 11:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
Tunnel adapter Local Area Connection* 13:
Description . . . . . . . . . . . : isatap.{84AFA9BD-6C1D-490A-915C-0F060A6DE
130}
C:\Users\Owner>
et NIC (NDIS 6.0)
130}
C:\Users\Owner>
