Intel Graphics Media Accelerator/Video Card Problem
gemnikkic
I have a Dell Inspiron 1525.
I seem to have broken my display when I was trying out the Intel GMA Driver's feature 'Flip 180' which supposedly flips the monitor's display. Instead it exhibited what would happen if you change your resolution to 640x480, with really large icons. I tried to restart the computer but when I checked in my display settings it says something like:
"The currently selected driver cannot be used. It was written for a previous version of Windows and is no longer compatible with this version.
The system has started using the default VGA driver."
And in my screen saver settings:
"The screen saver can't run because it requires a newer video card or one that's compatible with Direct3D."
Aside from that, the computer works perfectly fine, but I don't want this to be a problem in the future. What happened here? Is there any way I could fix this?
heres the driver for your intel chipset , try reinstalling it mate , this is for 32bit you dont mention which flavour of vista you have
Drivers and Downloads
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
If you look in the device manager, is the driver still there?
    Athlon 250 @ 3Ghz
    ECS 6100pm
    2GB DDR2
    9800gt Inno3d Green
    1366 x 768
