Researcher to Demonstrate Attack Code affecting most Intel Processors
Security researcher and author Kris Kaspersky plans to demonstrate how an attacker can target flaws in Intel's microprocessors to remotely attack a computer using JavaScript or TCP/IP packets, regardless of what operating system the computer is running.
Kaspersky will demonstrate how such an attack can be made in a presentation at the upcoming Hack In The Box (HITB) Security Conference in Kuala Lumpur, Malaysia, during October. The proof-of-concept attacks will show how processor bugs, called errata, can be exploited using certain instruction sequences and a knowledge of how Java compilers work, allowing an attacker to take control of the compiler.
"I'm going to show real working code...and make it publicly available," Kaspersky said, adding that CPU bugs are a growing threat and malware is being written that targets these vulnerabilities.
Different bugs will allow hackers to do different things on the attacked computers. "Some bugs just crash the system, some allow a hacker to gain full control on the kernel level. Some just help to attack Vista, disabling security protections," he said.
The demonstrated attack will be made against fully patched computers running a range of operating systems, including Windows XP, Vista, Windows Server 2003, Windows Server 2008, Linux and BSD, Kaspersky said, adding that the demonstration of an attack against a Mac is also a possibility.
Processors contain hundreds of millions of transistors and errata in these chips are relatively common. While some errata can affect a chip's ability to function properly -- such as the errata that last year forced Advanced Micro Devices to push back volume shipments of its quad-core Opteron processors -- many others exist unnoticed by users.
For example, the Silverthorne version of Intel's Atom processor, which lies at the heart of the Centrino Atom chip platform, contains 35 errata, according to a June specification update released by Intel.
"It's possible to fix most of the bugs, and Intel provides workarounds to the major BIOS vendors," Kaspersky said, referring to the code that controls the most basic functions of a PC. "However, not every vendor uses it and some bugs have no workarounds."
Source: PC World - Business Center: Researcher to Demonstrate Attack Code for Intel Chips
---According to the Intel Specification Updates... Intel Core 2 has 128 confirmed bugs. Intel Itanium (designed for critical systems) looks more “promising”, carrying over 230 bugs.
---They have all been confirmed by Intel and described in errata section of their specification updates. Some bugs “just” crash the system (under quite rare conditions) while the others give the attackers full control over the machine. In other words, Intel CPUs have exploitable bugs which are vulnerable to both local and remote attacks which works against any OS regardless of the patches applied or the applications which are running.
Full Article here: HITBSecConf2008 - Malaysia » Kris Kaspersky (Independent Network Security Researcher / Author for Xakep Magazine)
Ted
