InstallShield Wizard Problems
Insominies
I recently built a PC around March/April, everything went smoothly, installed Vista 64bit with no problems whatsoever and away I went.
Until I started installing games, anything to do with InstallShield Wizard slows my PC down to a crawl, using up to 98% physical memory which means I have to go downstairs for about an hour while it installs.
I narrowed the problem down to ASUS AI Suite, uninstalled the program and installs were going fine again.
However, I've reformatted and left out installing any ASUS software but the problem has come up again, only now I have no idea what is causing it.
Any ideas? Specs are as follows:
Help is appreciated, thank-you.
