Installing Programs not on C:
If you install programs on a drive other the the C: drive....
and you reload windows, will they all work, or
are parts dlls, etc. put on the C: drive.
Had to reload windows and now I need to reload all my programs,
want to avoid this in the future if possible :D
Bill
    Hp a6030n
Although we install programs on another partition or drive, there are critical things on the drive/partition where Windows is and your programs won't work if they are removed.
The best way to avoid having to reinstall all those programs is to create a hard drive backup using programs like Macrium, Acronis and others.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
The best way to avoid having to reinstall all those programs is to create a hard drive backup using programs like Macrium, Adonis and others.
But if you create a HD BU of C:, and windows is messed up?
Restoring the HD will result in windows being still messed up?
Or am I missing something?
Bill
    Hp a6030n
That's true. However, I was just trying to answer the generic question since it was given that you were going to reinstall the programs on a good copy of Windows. Note that I accidently said Adonis when I meant Acronis (must have looking at a picture of myself :D).
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
If you reinstall the OS, you have to reinstall the programs - regardless where they reside. If you want to avoid that, make an image of the OS partition and the partition with the programs after everything is installed and working. Then you can pull the images back in and need not reinstall in case of a catastrophe.
    Dell
    Q6600
    HP w2207h
Getting everything back in order.
I was looking at the macrium reflect programs.
Will the free one do what I need, only major difference I see is
file / folder backup. What I need is a disk image, correct?
Disk Imaging
Disk Cloning
Access images in Windows Explorer
Schedule backups
Linux Rescue CD
Windows PE 3 Rescue Media (RAID support)
Windows XP / Vista / 7 compatiblity
File and Folder backup
Email notification of backup status
Differential and Incremental backups
Technical support by email and forum access
Commercial and Business use
Disk Space Management
Backup scripting
Recovery from Windows boot menu
Password protection and encryption
    Hp a6030n
I think you want the disc image. You might look at the help file to see if you need something like opening an image file in Windows Explorer to restore the image. Usually Richc46 could provide more advice but I haven't seen him lately.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
    Dell
    Q6600
    HP w2207h
