Installing IDM problem(reg key damage)..!!
abdulfatha
I install IDM and try to run it but first a message comes like this saying
"Internet Download Manager detected its registry keys had been damaged since the last run.It's possible that you run a flaky spyware remover program which corrupted system registry. Internet download manager will try to restore all damaged data,But some data may remain corrupted."
Wat do i do...How do i clean up the registry..???
    HP Compaq
    Intel Pentium
    2gb
Yea thnks...I kno tht..jus ws lookin out if any othr way ws thr instead of restoring it...!!!!
    HP Compaq
    Intel Pentium
    2gb
Restoring has a bad name but its great. It will not touch personal documents. It returns you to the point before the problem. I use it, when necessary. Best for an uninstall, too, nothing left in registry.
If you are not sure how it is done, or you have problems, take your time. We will help you.
